Trailer tires
I just replaced the 13 inch wheels and tires on my trailer with 14 inches wheels and tires. Tires: Denman, 6 ply rating, ST205/75D14. I took it for a drive to check for clearance between the tires and fenders. Over rough road there was no touching of tire anywhere, except road. I stopped several times to check and did notice the tire sidewalls run hotter than I expected. Had never checked the 13 inch tires for heat. Is this to be expected? The hubs run cool so heat seems to be side wall generated. These are bias ply rather than radial. Is the heat normal?
tommays
Re: Trailer tires
If there NOT rubbing and inflated to there max pressure there is nothing to get them to hot
The problem is everybody has a different idea of what HOT is and i would think its pretty hot down your way right now
generaly there is a phone number to call about questions with the tire
Tommays
rickdb1boat
Re: Trailer tires
If you're running down the highway and pull over and feel them, you can bet they will be pretty warm. Not real hot, but sure, they're gonna be warm...Compare them with your car tires next time...
Re: Trailer tires
I did compare them to my truck tires (radials) and the trailer tires were much hotter.
Re: Trailer tires
Are they Inflated to the Maximun psi. listed on the tire's sidewall,..??.....
Tires Will run at Least as hot as the Blacktop they're riding on,...........
Like Tom says,........ Just How Hot is Hot,..??....
sleepinin
Re: Trailer tires
I had some tires I suspected were rubbing but I wasn't sure until I sprayed the inside of the fenders with white spray paint, took it for a drive and then checked the white paint for marks. Easy way to be sure.
battery
Re: Trailer tires
what size tires are on your truck? if the trailer tires are small then they will be turning faster and will be hotter then your truck tires
stopher
Re: Trailer tires
dual loadrite 14" tires...
i was driving in the misty rain and noticed my tires were steaming. i was worried that it was a serious problem; but it was the result of dewpoint, underpressure, and air humidity.
the tires were warm, the hubs cold, and the air cool. after a little while the tires must have expanded because they cooled off.
i wonder if the hubs were a bit sticky and worked off some corrosion while pulled until they began to spin easier. it took about 30 minutes on the highway. I stopped 3 times to inspect them. I wont' know if it is a hub issue until i repack them in the spring. i should do them in the fall, but I am not that enthusiastic to do it in the cold.
any insight on whether I should be concerned about the warm tires ?
Silvertip
Re: Trailer tires
If the bearings were the cause of the heat the hubs would be warm -- very warm. It would take a fair amount of time to transfer that head from the hubs, through the wheel then to the tires. I don't think that's an issue. Bias ply tires do run warmer than radials. Warm tires is one thing. Keep in mind they have to run hotter than ambient temperature. If its 80 degrees the tires will run substantially warmer than that simply due to tire/road friction. How much depends on speed, air pressure, and loading. Air moving across the tires at speed will bleed off some heat but they will still be above ambient.
