gjmsd
Thread starter- Joined
- Oct 18, 2010
- 83
I have a small boat (16' low profile with Evinrude 135) on a trailer. The trailer has 1" spindles. If I'm correct, this means it is a 2K lb axle. The tires are brand new and rated for 2600 lbs (1300 lbs each) and it has 4 brand new and well packed bearings. My thinking is that when we go boating, I'm also going to want to take the wife's jet ski along (best way I can be assured she'll want to go). With that in mind, I've built a cradle that sits in the boat to hold it and am in the process of welding up a lift to lift it in and out.
My plan is to lift it, launch the boat then drop it down into the water. When we are done, I'll lift the jet ski, pull the boat up and lower the jet ski back into the cradle.
My concern is whether the trailer can handle the weight towing it 400 miles round trip to where we boat. If I calculated right (and guessed right), I should be well below the limit but am still a bit nervous and would love some input from people more knowledgeable than me on trailers.
Weights of everything
Boat hull - 500 lbs (rough guess)
trailer - 300 lbs (rough guess)
motor - 271 lbs
lift and cradle - 150 lbs
jet ski - 455 lbs
TOTAL - 1676 lbs
motor - 271 lbs
jet ski - 455 lbs
TOTAL - 1676 lbs
