trailer wiring diagram help
joeyd50
Help please, I have a 1994 Nissan Pick up with the separate yellow turn signals, I know the yellow wire is for LH stop and turn signal, the green is for RH stop and turn signal, brown is running lights and white is ground. that?s fine if your brake and turn signal is the same light but I have a separate brake and turn signal lights. Can someone tell me how to wire my truck to the trailer with the 4 wire flat connecter? The 4 wire flat connecter is already on the trailer.
Thanks
Joe
burroak
Re: trailer wiring diagram help
You need a Nissan adapter.You have a seven pin and need to get to the four pin. I think it is a Nissan part. You may need two relays, also. Smooze your Nissan parts guy or locate what you need in a boneyard.
JB
You need an adapter with the diode "OR" gate in it. Most auto supply stores sell them.
tashasdaddy
this should help you, "http://www.easternmarine.com/em_store/tech_info/light_tech.html"
