Auberon
Thread starter- Joined
- Jun 27, 2009
- 8
After a couple boat launches my new-to-me trailer keeps blowing the trailer fuse in the Jeep, so I checked the wiring and lights and decided to throw it all out and put new wires and lights in.
The old wires rubbed off their insulation at the points where they go inside the frame, and to make things worse, those holes were not drilled and protected with grommets, but just torched and painted over. Pretty sloppy work IMHO, and when I checked another trailer from the same manufacturer, just much younger, those holes where drilled and at least the wires where run through washers. Not perfect, but at least someone had a second thought.
I am thinking now of running all wires outside the frame in wire loom, any pros and cons to that? How did you rewire the trailer?
Auberon
Auberon
