trailer wobble at low speeds
sikz3
Any ideas what could cause boat and trailer to wobble at 20-25 mph? It is fine below 20mph and above 25mph.
The trailer is a single axle roadrunner 14" wheels.
xtraham
Re: trailer wobble at low speeds
seperated belt in a tire possibly
jtexas
have you inspected the tires closely for defects?
checked inflation?
sticky brake caliper or warped rotor?
"wobble" - is it something you can see, or feel, or hear while driving? Maybe have someone outside the tow vehicle observe it.
I would think a Bad Tire,........
Or,.... A Bent Wheel.........
Or,..... Very Loose Wheel Bearings............
Any 1 of the 3 will Ruin your Day.........
I Wouldn't Move the Trailer til the Cause is Found........
sikz3
I have already taken it to the lake about six times since it has been doing this. I will get it down to the tire shop this week. Thanks
Silvertip
No need to go to a tire shop. Jack up one side, give the wheel a spin while watching the tread. If it has an obvious wiggle to it, a belt has separated. While its jacked up, rotate the wheel while looking carefully at each sidewall. Any bulges indicates tire damage and the need for immediate replacement. Place a fixed object close to the wheel rim and spin the wheel. Watch the gap between the object and the rim. If the gap varies you have a bent wheel. If the tires are radials, some of them develop what's called radial tire waddle. Very annoying on a car and it can also cause a problem on a trailer. Again, its belt related. Are these trailer tires or auto tires. Trailer tires are marked "STxxx-xx on the sidewall.
bjcsc
If the tires are not radials, they're bias-ply. It's normal for them to do this until they "warm up", esp. if they've been sitting awhile.
sikz3
Wouldn't they have caught this stuff when mounting and balancing the tires? They are st tires. I have an appt. tommorow at the tire shop to have this checked out and have the wheel bearings replaced. wish me luck. I hope it is not a bent wheel.
