Re: Trailering motor in the up position
I can understand how a transom saver can be a royal pain to connect, my one boat came with one, the rear cross member of the trailer though is way underneath, only the roller arms come to the back of the boat. A transom saver would have to be 6' long to reach the tilted motor and rear crossmember.
I made up a fixture out of stainless rods, which extends the locking position of the motor about 9" when in tow. This puts the motor up enough not to hit the skeg, keeps the weight well supported and locks the motor in place.
On really long trips, I tend to put a ratchet strap across the motor too just for good measure.
My 1995 Mercury 115 came with a towing bracket which slides into the tilt bracket and does the same thing as the one I made for my Evinrude. On one motor with no down latch, I made up a block that I can pin in place with an extra tilt pin with a trailer bow stop mounted on it which I then tie the motor down to with a ratchet strap.
I did buy one boat on which a previous owner had attached the clevis bracket of a transom saver to the lower transom and not the trailer. It was on a larger aluminum boat which also sat on a trailer with no rear crossmember to attach too. I didn't like it, but it didn't leak and it did seem to work well, but I didn't keep that boat very long but mostly due to it's size and weight.
