Re: Trailor
You misunderstand how the lights work. The tail/stop/turn signal lamp bulb has two filaments in it. The normal tail (running light) lights the dimmer of the two filaments. The stop and turn signals use the other filament. Since the drivers side works, you do not have a "trailer" ground issue. What you do have is a break in the stop/turn signal wire for the passenger side. It is also possible that you have inserted the bulb in correctly. Yes -- the bulbs are keyed so they only go in one way, but the lamps are made so cheaply it is easy for folks to put them in 180 degrees out. Hold the bulb so the little nubs face right and left. Note that one is slightly higher than the other. While you are looking at it, check both filaments. If the bulb is bad one or both of the filaments will be broken. The lamp itself also has a good ground because the tail (running light works). The brown wire in the trailer harness feeds the tail lights. The other wire going into the light is the stop/turn signal wire. Check that wire back to the plug. Somewhere along the line it is either disconnected or broken.
