Trailstar Trailer Tire Abnormal Wear
bigesox11
I have extreme inside wear on my Trailstar trailer single axle trailer tires that trailer my 2002 Tracker DV16. I was told that I probably have a bent axle. Could it be something else that is causing the abnormal wear and can the axle be straightened if it is bent?
The inside edge of both tires is "choppy", almost as if there are cuts in the tires, but only on the inside edge. Any thoughts or opinions? Thanks.
msgcoons
Re: Trailstar Trailer Tire Abnormal Wear
Both tires would not be a bent axle. Most likely your tires are not inflated correctly, or a bad set of tires. Check on recalls on the tires with the manufacture. For the heck of it place a vertical next to your tire. See if the bubble is centered. MMMMMMMMMMMM....Always inflate with the trailer loaded. Those are my best guesses.
