Transducer mounting on a tri-hull
wildracing22
I have done a good bit of research into transducer mounting options though nothing seems to pertain to a true tri-hull boat. Does anyone have any ideas, i hate to mount it to one of the outside hulls and literally be viewing what is at one side of the boat. I have a great location under the center hull that I am working on getting pics for. Please, any help would be greatly appreciated.
CATransplant
Re: Transducer mounting on a tri-hull
Mount it to the side. It won't make any difference in what you see, or at least no appreciable difference. That's where I put the one on my old trihull, and it worked great. Too close to the outboard or drive, and you'll get turbulence that will destroy the view on your screen.
wildracing22
Thank You, I knew the best place would be on the outside but i have a problem with thing being off center. I will place it there then, I am afraid of the turbulence I may encounter if it is on the center hull. Thanks again, CaTransplant!
