Transducer
Hardh2o
I have a 1989 Fourwinns 180 Candia. Depth gauge not working. Where is the transducer located? Any suggestions on where to start?
Texasmark
Most common is mounting on the transom of the boat. Some mount inside the boat just in front of the transom. Some are through hull which you can find by looking for a round disc (usually) type "plug" up under the hull, probably near the stern.
Texasmark
If through hole type, finding the location from outside the hull will tell you where in the bilge to look for the ducer!
