Transfer Ports
basstracker1970
As I was checking out the bleed restrictors I noticed how rough the beginning of the transfer Ports are. Can these be smoothed out without hurting anything? I attached a pic to show what im talking about.ports 005.jpg
sschefer
Re: Transfer Ports
As I was checking out the bleed restrictors I noticed how rough the beginning of the transfer Ports are. Can these be smoothed out without hurting anything? I attached a pic to show what im talking about.View attachment 73569
Actually, those are smoothed. I've seen them with the casting flash still in there. I don't think it will hurt anything to clean them up if you want. I wouldn't get too carried away unless you've got someone experienced looking over your shoulder.
daveswaves
Ensign
Re: Transfer Ports
If you are referring to the orange peel finish that is there for a reason. It stops boundry layers of air/fuel from forming and keeps the fuel in mixture with the air. Sharp flashes can be removed.
Faztbullet
Re: Transfer Ports
You can smooth up the casting where red arrow are but you wont see any increases in performance. Remember air travels around a curved edge better than a square edge. I even had a set of flat covers made with welded deflector to try to increase crankcase volume & flow to cylinders. What I found was and it made engine a dog at midrange rpms and lost 800 rpm on top end.
basstracker1970
Re: Transfer Ports
Well if it's not going to help anything I will just leave them alone. Thanks for all the feedback on this. I hope everyone has a great and safe thanksgiving...
