transmision oil change
JC1933
Hi everyone,<br /><br /> I have a 1996 Ford Torus it has 145000Km on it i have never changed oil, this converts to 90103 miles. The oil is clean looks like new oil,smels like new oil, is it OK or should it be changed?---J.C. :rolleyes:
ZmOz
Re: transmision oil change
Should have been changed about 60,000 miles ago.
KRS
Banned
change it!!! Be sure to clean the pan magnet and replace it.
JC1933
Thanks Guys.<br /><br /> We shal do that,--J,C,-- :cool: ;)
deputydawg
To do this right you should drain the torque converter too. It is kind of expensive (around $110) but have a mechanic back flush the system. <br /><br />I have found that every 40,000 to 60,000 miles is a good range to change this, depending on use. <br /><br />If you don't empty the torque converter then the old fluid in there will contaminate the new fluid.
Manipulator
If you were to do this yourself, how hard is it to drain the torque converter? I have a Ford Expedition.
Friz
manipulator, jct, don't try to backflush it yourself. Let someone else do it. I have seen a guy run a 5 gal bucket of tranny fluid to the pump intake to flush out all the old oil, but he still had to change the filter. What a mess.<br />I have my tranny in my one ton truck serviced every 25k miles. It's worth the $80 to have it done right and ensure that I won't have to buy a $3000 transmission.
Moody Blue
Porbably a good idea to change the oil BUT here's what happened to me. Had a 1990 Safari van that had 346,800KM (208,000miles) without a single transmission oil change. Still ran strong when I sold it but the body rotted off it. My next van, a 1996 Safari, had the oil & filter changed every two years as part of an 'improved' maintenance regiment. At 203,000KM the tranny went for a cr@p. Litterally chunks of gears in the pan. Preventative maintenance is always a good thing but, I think if it is going to go, it is going to go regardless.
deputydawg
Older cars had a drain on the torque converter. Remobe the access plate at the bottom of the bell housing and pull the plug.<br /><br />New ones don't have this. It is well worth the money to have someone else do it. It is messy and takes a lot of patience and time. You'll end up running a quart of oil onto the ground, getting the stuff in your hair and down the back of your shirt. Just not worth it unless you have a lift.<br /><br />Oh, I almost forgot. Have to drain the tranny cooler out in front by the radiator.
D
DJ
Guest
The Taurus does not have a converter drain. A "flush" is the only method that will do any good.<br /><br />MAKE ABSOLUTELY SURE that the service facility puts the right fluid back in. Check your owners manual.
