transmission temp to cool?
muskie hunter
I have a 1997 Gmc yukon. The transmission is a 4L60e. I added a secondary transmission cooler and a trans temp gauge. When I am not towing the boat, the trans temp runs about 110-125. I know that optimum temperature is 175(which is what it runs while towing the boat)
Will to low a fluid temp harm the transmission? What are the ramifications of low fluid temperature if any?
What is the hotest acceptable fluid temperature before shortening the transmissions life span.
Thanks Steve
Skinnywater
Re: transmission temp to cool?
You're fine, however you could wrap the additional cooler to block airflow during the colder weather.
That's the problem with guages sometimes. They tend to elevate worry by indicating conditions rather then problems.
While 175 might be optimal, it's all give and take. Rarely is everything optimal all the time. And in this case less then optimal on the cool side is favorable.
However, your observation brings up one of the reasons one should utilize the existing "heat exchanger" already provided in the radiator when adding an additional cooler.
230-250F is considered overheating. But keep in mind when it comes to A/Trans and overheating; I watched a temp guage on an Allison go from 175 to over 300 deg. in 15 seconds under a heavy load.
It literally "smoked" the fluid.
dolluper
If your in cold winter country you might even want to disconnect the aux cooler and run through the rad lines only,like Skinny said. I believe with a 97 your just before fuild temp sensors think they started in 99 up can't remember,anyways if not watch out for a check engine code PO711 it's for fuild temp sensor out of range ,pretty much any of the PO700 codes starting at PO705 -785 are trannie related but then you move to P1810 -1860 and 1870.....P1870 is the BIGGIE Tranie is slipping
jeeperman
Your transmission is designed to function ideally at the same operating temperature of your engine.
If the factory wanted the trans to run cooler then normal engine temps, they would not have the factory cooler in the rad.
With the cooler in the rad and the idiot lights and gages warning of high engine temps, they also save the tranny if you heed the warnings.
Kenneth Brown
I'm in agreement with the others here. You should run the cooler through the extra cooler first and then through the factory radiator cooler. This will normally bring it to the area it should be in.
muskie hunter
The truck came factory w/ the tow package (oil cooler,trans cooler)
The routing of the cooler: the trans line went into the radiator,out of the radiator, into the cooler, out of the cooler and back into the transmission. Now: the line comes out of the transmission into the radiator out of the radiator into the cooler out of the cooler into the secondary cooler, out of the secondary cooler and back to the transmission.
The B&M cooler that was installed has an automatic fluid bypass. When the fluid is cold It does not flow thrue the cooler, it bypasses it and goes directly back to the transmission.
Steve.
SuperNova
At 200*F modern fluid life is 100,000 miles---at 300*F it's useful life is 20 minutes--so using the radiator to cool it to eng temp gets it in the ballpark and is very efficient generally. Using the aux cooler is added safety margin, but does reduce cooler flow somewhat ( need I remind you that cooler return oil is used for lubrication) now you've gone and added another cooler, thus reducing flow even more--so what is going to kill your trans won't be high temperature fluid degradation--it'll be lack of lubrication flow. Bye Bye thrust bearings and planetary gearsets...been there seen that...about a thousand times.....esp. on a 700r4/4l60e type which aren't noted for good cooler/lube flow to start with.
Stan
dolluper
The best fix for low flow issues we found was by adding a couple extra vanes to the oil pump,it increased the longivity quite a bit,Esp in lock-up mode when the flow has an increased drop almost to nil ,by adding a shift kit also helped but if you didn't add an aux cooler with the shift kit it burn't up the pump to casing seal
reelfishin
Too cold won't hurt it.
Where are you taking the temp reading?
If it's in the pan, keep in mind that thats not the temp of the fluid in the converter. That's were the heat will be the highest when towing.
It's general rule of thumb that the colder you can keep the trans fluid the longer the trans will last. You can block airflow to the cooler in the really cold months, especially if your not towing, but most coolers are positioned close enough to the radiator to absorb some residual heat when standing still. My only concern in the winter would be seal effectiveness if the temps got too low.
I run a 10 x 15" stacked plate cooler on my Dodge with an auxiliary fan on the cooler. Fluid temp in the pan read by using the OEM temp sensor reads 121 after a long run, but an infrared temp reading off the torque converter is about 200 degrees after coming back from a hard run with a trailer. The Cooler is cold to the touch at the same time from the 30 degree air. The pan is warm, but not hot, after a bit of a hot soak, the temp rises to about 180.
I added an aftermarket temp gauge and a drain plug when I redid the trans last year, I positioned that sender near the converter dump port. It reads about 135 empty at cruise and about 190 max when pulling a heavy trailer. My feeling is that it's getting the most accurate reading possible from fluid that has just returned from the torque converter.
I also added a cast aluminum pan to allow the fluid to dissipate heat faster, it's extra deep and also adds about 3 - 3 1/2 qts. of capacity. I use that truck for all sorts of towing, not so much for the boat. It normally tows a three axle equipment trailer with about 10K on it. I also made other modifications to that trans when I rebuilt it. but the gear ratios were left stock. My main concern was hydraulic clamping force and planetary gear life.
The 46RE isn't known as the strongest in its class. I did what ever I could to make it survive. It's been about 40K since the rebuild, time will tell how it works out in the long run. The original trans only went 30K.
dolluper
Humm The 46RE isn't known as the strongest in its class. I did what ever I could to make it survive. It's been about 40K since the rebuild, time will tell how it works out in the long run. The original trans only went 30K.
Good thing we are talking GM's instead of those ones I could write a book on their faults diffentily they need more vanes in their pumps
MikDee
Banned
IMO, Running 100-125* is not really cold, I would think that if anything the viscosity of the fluid at that temp is better for long term durability.
SuperNova
Dodge trans don't have vanes in their pumps---they are ALL gear pumps. Even the FWD car and minivan transaxles. The real problem with repeat failures is people who get a trans failure and don't flush or replace the coolers.
muskie hunter
I have the gauge threaded into the high pressure port on the driver side of the transmission just about 5" above the transmission oil pan. Initially I didnt think the temp gauge was working because it always regestered 125. I found out that it was working after pulling my boat (Wellcraft 26 SE Excell). Temp gauge came right up to 175 and stayed there.
Thanks Steve
byacey
My only concern would be in cold weather. If the fluid runs too cold it won't upshift into torque converter lockup in 3rd and 4th gears. These transmissions (depending on the year) have a thermal switch that disables the lockup clutch until the transmission is warm enough. When the transmission is cold the torque converter actually generates a considerable amount of heat when under load. This help heat the oil up to operating temp faster and enabling the lockup clutch thermal switch. Once the Torque converter is locked up it doesn't generate much heat at all.
Skinnywater
I had a customer drive 30 miles today non-stop @ 60-65mph today to have me check his A/Trans fluid level. It was a 2002 CLK320, they don't have dipsticks. The car was stock, only had a cooler in the radiator.
The ambient temp. today was 57f or so.
While I was measuring, the temp. of the ATF was what I would estimate @ 130f, only warm to the touch.
I do know from experience it takes a loooooong time to get ATF hot under normal driving.
reelfishin
Did you ever try doing a trans service on a truck that just rolled in off the highway? Can you say blisters and 3rd degree burns. I worked for for 15 years at both Ford and Mopar dealers and 5 at a GM shop, mostly only on trucks. We all would dread having to service a drive in customer trans. A passenger car that's been driven in cooler weather and unladen won't gain the temp that a work truck will or one that's been towing a trailer.
It's 34 degrees out here, and I wouldn't think of going outside and trying to touch the transmission pan or bell housing area on my truck after a 20 mile drive. It probably wouldn't burn skin, but I'd be willing to bet that the average person couldn't hold their hand on it. I'd venture to guess that the case temp of that trans is in the 160 -170 degree range or more. A transmission not only makes it's own heat, but being that the case is aluminum, it also absorbs a certain amount of heat from the engine, both from proximity of the exhaust, it's being attached directly to the hot engine block, and the fact that nearly all transmissions are cooled with engine coolant being that the factory cooler normally is inside the radiator tank.
The temp of the fluid can vary depending on where you take the reading. Fluid coming back from the cooler or just being picked up from the pan will be a lot cooler than fluid which has just left the torque converter.
The trans pan itself tends to rid itself of some heat simply due to air flow over it, but at slower speeds and harder driving, this is negligible. There is no substitute for a good cooler as well as the proper rear axle ratio in a tow vehicle.
Supernova is correct that Mopar doesn't use a vane pump, they retained he gear pump design over the years. There are several common problems with the Mopar trans, what I tend to see the most is simply lip seal failures and solenoid failures. Normally a properly rebuilt trans will outlast the OEM trans if a few simple improvements are done.
Having worked on all three major brands, I would say that the best in class would be the GM TH400 and 4L80E trans, then I would say the Ford 4R100, with the Mopar A518/46RE/47RE being at the bottom of the list. The Dodge trans is probably the simplest design, it's more or less just an adaptation of the older 727 three speed. When it comes to the smaller transmissions, GM's 4L60E, Ford's 4R70W, and Dodge's 42RE, the GM and Ford offerings are about equal, with Ford maybe having a bit of an advantage in longevity when towing, but the GM 4L60E may have a slight drivability advantage with a lower first gear ratio. The Dodge 42RE/A500 is just pitifully too light duty. Unfortunately Dodge used the lighter 42RE/A500 trans in most 1/2 ton, Durango, and Dakota trucks as well as many vans up to the D250 class.
I've rebuilt transmissions professionally for years, both in dealers and private shops, they all have their weak points, but some are just poor choices when it comes to owning one as a tow vehicle. I generally prefer Fords, but my Dodge and GMC trucks came to me as part of a business deal, I will run them so long as they are viable vehicles. When I rebuilt the trans in my one ton Dodge van, what I found was a failed intermediate clutch piston seal, broken OD accumulator spring, and slightly burnt direct clutches. An overhaul kit, a couple of new springs, a thorough valve body cleaning, a slight adjustment to boost control pressure a bit, and some new solenoids along with a complete cooler flush and the addition of a super sized RV stacked plate cooler and it should be fine for a long time. I also upgraded to the diesel spec planetary gears and hemi ratio servo lever.
It shifts fast and firm without being harsh, before you couldn't tell when it shifted. A fast shift makes for a cooler trans since it reduces the time which the clutches are slipping or not fully applied between ratios.
Anyhow, back to the question at hand,
As far as a trans being too cold, its not likely ever going to do any damage. There's enough heat in the system regardless of how well you cool it to keep it from running 'cold'. The only 'Cold' situation that would concern me is when running it in sub freezing weather without proper warm up. Once the engine is warm, the trans is too. As far as when to worry, I'd start being slightly concerned at around 200, and worried at say about 230 or so and really concerned if it got there and steadily began to keep climbing upwards. A temporary spike in temp when towing or climbing a hill is normal.
What does your boat weigh? How far are you towing it? How long does it take for it to gain the added temp over normal? Flat or hilly terrain?
I am assuming that you are towing with the OD or towing switch off?
On my Dodge van, I eliminated the factory cooler and am running an over sized stacked plate cooler, I believe it may also be a B&M product. The way I feel is that the added cooling won't hurt since it's a 1 ton truck thats rarely driven without either being loaded or towing a trailer, and a transmission doesn't need the added heat from the coolant or vice versa. It was the right choice in my case, your driving habits and general use may be quite different than mine. My Dodge is a work truck that does double duty as a part time tow vehicle, and I only use it when I need the added size due to it's poor mileage.
muskie hunter
Thanks for the great information. I forgot to mention that I am running a Hypertech program that improves shift firmness.Also a 164 degrees thermostat from Hypertech. The boat and trailer with fuel is estamated at 6800. General tow length is about 80 miles mildly hilly terrain.The trans runs at 150 w/o boat during the summer.I get to max temp (175-180 ish)in the summer while towing in about 25 miles and I tow in drive not overdrive. I dont fight to hold speed on hills, but simply hold the accelerator in place and let the speed fall where it may. Usually the speed drops from 65 to 55 and havent yet seen it drop below 50mph.
The truck is rated to tow 6500. It is also only used to haul trailers,cut firewood and hunt and fish. When I use it it I am generally working it.
Thanks Steve
SuperNova
All that hypertech programmer does is boost line pressure---it can and does damage clutches and piston seals. Use it wisely and not excessively.
Stan
muskie hunter
Stan
Stan
The hypertech programmer does not allow me to fine tune anything on the truck. It simply asks a series of questions about tire size,gear ratios,fuel octane used, transmission shift firmness ect. By answering the questions it then reprograms the trucks computer.When programming is complete the Hypertech unit is unhooked from the trucks computer port.The unit cannot be turned on and off either the truck is running the hypertech program or it is running the factory GMC program.
Thanks Steve
