1NewBoatGuy
Thread starter- Joined
- May 9, 2013
- 94
So I recently bought a 1985 Bayliner Capri, this is my first boat. Not being aware of what I needed to look for I for some reason went against my gut feeling and trusted the seller of the boat. The boat had been stored outside and was full of leaves. He said it is pretty solid and that it only needed new floor boards and ran fine the year before. He started the motor and everything sounded right to me. I did see an aluminum plate over the transom and assumed the dirty work had already been done and that it was there for precaution. After all if i repaired a transom I would also be pretty cautious and would want to add additional support.
Well I tore out the the floor and started in at replacing the floor. After tearing out the floor I could see the fiberglass separating from the stringers. I decided not to be concerned with this and just put new boards in and sealed up the floor. After closer inspection and cleaning up the boat I found the supports for the transom were cracked away from the back of the boat. Hence the reason the motor flexing the transom so much when going down the road. DAMN...:mad-new: :facepalm:
I watched countless youtube videos and read many threads on transom repair. My conclusion is, once I start if I don't get it right, it is a total loss. As it is I may be able to get my money back from a Craiglist sale.
So the question lies here. Is it worth the time and money to make the repairs to this old boat, or should I hit craigs list with my new found knowledge and look for a more worthy project?
