Transom assembly leak
scoflaw
Ensign
Looking for some help from someone that may have had a similar leak. This twin engine boat is very tight in the ER, and I can't get a visual on the source, but I can see water running down the transom if I look under the motor only when its underway.
Won't leak a drop sitting in the slip even when the motors are running. Thanks for any help. It's a very clean low hour boat with no visible corrosion
Re: Transom assembly leak
Ayuh,.... Grab yer digital camera,...
It, in yer hand can see places yer head won't fit,....
