HalfFish5087
Thread starter- Joined
- May 30, 2012
- 278
Gents,
I have two things that I would like to run by some more experienced boaters. First, are the fatigue cracks in the below picture anything to be concerned about? They measure approx. 0.002 to 0.003 inch in width. I have tried to notice any movement by pressing pretty heavily on the outdrive and not observed any movement. Secondly, on the bottom right you will notice that this area has been chalked numerous times. (I had removed the majority of bad portion before taking the picture) Two times by myself with 5200 and yet the caulk has failed to adhere to the metal on the outdrive which then in turn lets in water at a rate of about 3 gallons in 12 hours. Not much, but if it?s something I can prevent I?d like to try and fix it. So, I?m left thinking maybe I got a bad tube of 5200 or is there another silicone or maybe even epoxy that I should consider?
Boat is a 98 226 Larson, 5.7GS, DP-S1 Outdrive, TSK SX-C1 Transom with 173 hours.
Thanks for the help!
HalfFish
HalfFish
