While I'm still thinking about how I want to redesign my splashwell on an older 72 Reinell bowrider, I had an idea while sipping a shot of vodka and staring at the thing. I have the plywood mounted in the transom, the stringers in, and as I removed the entire splashwell...I am now thinking of a better idea. Someone tell me this is not a new idea, because I can't believe I haven't been able to find it on the forum. Why not run the splashwell drains SIDEWAYS through to the hull, thereby removing two more holes in the transom? To allow for flex, perhaps brass threaded fittings, connected between splashwell and hull with flexible hose, similar to a bilge pump connection? I'm at that phase where you sit and stare at the concept being built, and this hit me...as I dread putting any holes in the new transom. I bounced this off a commercial fisherman guy I know who's done many transoms on pleasure boats, and the brass was his contribution....but he thinks it's a very good idea. Anyone else try that here?????
On a similar subject, this friend put no bilge drain through the transom on his last 2 he built, relying on a bilge pump if ever needed. (Same concept, fewer holes through transom.) I'm leaning towards this as well. Might as well go all out, and mount the fish finder/transducer into th einside of the hull, and glass it in....
