Hello<br /><br /> My boat is made for a short shaft motor. It is a 1979 Lund 15 ft Rhino aluminum boat.I recently took off my Evinrude 40 HP 1976 short shaft model and replaced with a 1986 35 hp long shaft merc. I purchased a product from T&R Marine called a transom elevator to raise the engine mount 5 inches.I have everything mounted up and the new bracket is very solid. The question is there is a slight flex to the transom when I put some torgue on the lower part of the motor. Still on land I haven't tried it in the water. Is this slight flex ok or is it something to worry about. I never checked for the flex when I had the 40 on the rig. I never thought to look. I had the 40 on for 3 or 4 summers with narry a problem. Thanks for any input.
