Transom/Gear Case size
FillupD
I would like to find out what would happen if a 15" transom(small gearcase) was mounted to a 20" transom. I am trying to swap motors but the 76 55 hp I bought has a small gear case and I have a 20" transom. I have a 73 50hp lark but I'm not sure if the gearcase will interchange.
If I run with the small gearcase, would the cavitation plate just be too high to expect good performance? or would it even work?
Silvertip
Re: Transom/Gear Case size
That's why they make 15 and 20 inch legs. Generally a 15 inch leg is too short on a 20 inch transom. It will work fine off-plane but when you get on-plane the prop will very likely ventilate.
ondarvr
Are you sure yours is a short shaft? There were short shaft (15") 50's and 55's, but they weren't that common, most were 20" models.
FillupD
I'm going over to IA to pick it up now, I'll know in about 4 hrs for sure. I was just going by what I have read, 15" transom and small gear case. I thought maybe the large gear case would be better though; maybe not, maybe doesn't matter. As you can tell I really don't have a clue about these gear cases and size differences/or why there is. I have a few props for a large case though so I thought switching may be a god idea from that stand point, and possible other benefits?
FillupD
Ok, It is a long shaft with a small gear case. Is there a difference between the gear cases that would merit a change to a large gear case? Would it even work. I'm going to pull the lower end from the motor I just got that's been sitting for awhile and change the impeller, its the same impeller part number maybe the shafts will be the same and I can just swap the cases. I am thinking there has got to be some kind of advantage for a larger gear case versus the smaller one.
ondarvr
I'm not sure what he means by a small gearcase, other than for high performance and racing I don't think there is a small one. The only thing I can think of is that a commercial model may have a larger gearcase than a standard model, but I've never seen one with it and they normally rate the HP lower on commercial models.
FillupD
On my 50 hp the prop is a 4.5" and on the 55 it is a 3". It states in the description for props, small gearcase or large gearcase.
I just wanted to swap my large on on the 50 to the 55 if there was an advantage (other than I have props for the larger one)
I just had a question: Can the gear cases be swapped, and is there an advantage of the large one over the small one?
