transom height from keel for 78 evin 70hp
dcfrost
Can anyone tell me what the distance from keel to mounting edge of the transom should be for a 78 Evinrude 70..... it is a 25 " long shaft.....new at this !!!!!
Dhadley
Re: transom height from keel for 78 evin 70hp
I didn't think they made a 25" 3 cylinder 70. If that's what you have the transom should be 25" but I think you may have a 20" motor. Unless you have a 75 then it may be a 15" motor. Where are you measuring from? It should be from under the mounting "ears" to the antiventilation (cavitation) plate just above the propshaft.<br /><br />Good luck!
dcfrost
thanks for the info, I am going to check it out today.
dcfrost
checked again, right on 20", thanks for the input.
Dhadley
Good. Your transom should measure right about 20 3/4". <br /><br />Sounds like youre all set!
