Hello,
I'm new to iboats and have spent many hours reading posts of all who have endured a boat resto.
I unfortunatly own a Nova 1700 which requires (setting fire too) stringers, floor and transom.
The bottom of the transom is starting to go soft and i'm trying to convert the hull to an outboard as was a Merc stern drive. I started to remove wood but its proving nearly impossible.
My question can i cut the whole transom out leaving 4 inch around each side to join new fiberglass / Plywood to? I will be bolting on an old 235hp Johnson VRO XL shaft.
In the photo attached i have draw a line around where i intend on cutting transom.
Any help would be great as i'm unsure if it is good practice to do the transom this way.
Thank you....Daniel
Thank you....Daniel
