I've been trying to figure out what was wrong with my transom
Transom Issue
and while I was going to start drilling test holes, I put my finger inside the drain hole for the splash well, and SH!T my fingers could do a full 360 sweep and it was complete mush inside of there.
Finally pulled the motor off and removed the metal plate protecting the top of the transom, and was preparing to remove the top section of my boat, and well... I can't
it appears to be bonded together were the motor mounts to the transom and its frickin thick!!! I used my angle grinder and cut a section out of the splash well transom area, and its almost 1/2inch thick!!!
I'm currently digging out the old wood, and while clawing at it with my wreaking bar I kept getting splashed in the face with water:redface: so its really bad, going to finish ripping it out and begin measuring pieces to fit in place for the transom.
However seeing that the top section of the boat is not removable can the transom be installed in two peices? Or will this cause more problems
Transom Issue
