transom other than wood
jay the fisherman
Re: transom other than wood
thats what i want thanks that will last longer than anyone on this planet will
kfa4303
Banned
Very Cool. Any pics of how you made it?
Yacht Dr.
Jay - I'm like you... If a wood transom was such a great thing, no one would be posting about replacing them. I NEVER want to replace my transom - ever again. I went on a wood eradication campaign on my boat (I could just feel it rotting while I was on the water). You might check around for fiberglass distributors. I ended up getting some odds/ends pieces of fiberglass laminate (cost me ~$20). I laminated the pieces to the desired thickness, then cut it to shape. Hard as he!! to cut, but you can get a jig-saw blade that's appropriate. Here's a picture of my transom.
Never will have to do this job again!
What kind of " fiberglass laminate " did you use ?
What kind of " appropriate " jig-saw " blade did you use ? ( Id really like to hear this because I just cut through 3/4" solid glass panels that I had for about 5' and smoked a few blades ).
Wood has been used for decades in boat transoms..done correctly It will still outlive you ( probably not outlive Forever but ..eh.. ).
YD.
sublauxation
Now that is a work of art. Nice work. I couldn't find the composites that were listed last summer, he must have sold them all, I'm kicking myself for not buying one or two. I second the post pics of the process if you've got em request.
ondarvr
Solid glass weighs about 1lb per sq ft, per 1/8 inch, so a 12"x12"x1" piece of solid glass weighs about 8 lbs.
At 6'x2'x2" (just a guess on the trasnom size) it would weigh about 192 lbs. being solid glass.
If it were me I would use plywood and epoxy and then check it again in about 15 years to see how its holding up.
tboydva
Boy, i wish it was 192 lbs (I would feel like a really strong dude!). The glass "sheets" I got were heavy, but I suspect the transom weighed about 40-50 lb in the end. It was certainly heavier than wood, no doubt. Ondarvr has the practical solution without a doubt. I have a particular perversion about things like this. My wife will say, "Cover it up with some trim and it'll look great." I'll be thinking, "Yeah, but I'll always know it looks like crap under that trim."
As I say, totally impractical, but for a freak like me, I love knowing there's no wood to even have the possibility of rotting (and I know this boat will be sold or retired before it would rot anyway.... I know it, so it doesn't have to be said...).
I posted my arduous resto on the "finished" part of the site. The jigsaw blade was here. I'm pretty sure I used all 5 for this job... Cutting the bevel on the sides was particularly difficult.
Not sure how you can check for this fiberboard "locally." I was visiting my brother-in-law and he knew a guy who worked at the plant (and amazingly, he lots of odd sizes for sale!). Ondarvr is right though. It is far heavier than wood. Strength-wise and bend-wise, it's all kind of solid!
Yacht Dr.
Thanks for the linky on the blades tboydva :) .
I dont cut many thing thats solid glass with a jiggy..I use them big boys. But for finesse cuts that last set of dewalt "super blades" were a joke.
Gonna get some asap and stuff them in my "go-to" box :) .
YD.
jay the fisherman
my hull is all been done with the gluvit and ordered my coosa board yesterday it was 300 dollars shipped to my door not bad considering you just cut it to shape and drop it in and it will last forever much better than wood if you ask me i got it from a company called total plastics in baltimore marayland for the cost of wood time and apoxy the coosa is the way to go hands down so you can
saxrulez
Lol.
I used coosa in my transom and I don't regret it. Definitely more costly, but it did save a lot of time and work, especially for a guy like me that had never worked with fiberglass before.
jay the fisherman
just another believer if wood was so good there wouldnt be so many transome replacement threads
jay the fisherman
its bee a long time but i went with the coosa dont regret it a bit 308.00 for a 4by 8 sheet 1inch thick pricey but well worth it nomore worrying about the transome for the life of the boat also replaced all my decking and consoles with marine grade plywood coated on all sides with three coats of grizzly grip roll on bed liner its like dipping it in rubber it will never rot again and very durable comes in many colors also a bit pricey 85 dollars a gallon but again now the deck and consoles will be there for ever
Cadwelder
I don't get using the coosa for the transom and then going back with wood for the rest??? The coosa is good stuff..used it before. But if rot is the issue, doing just the transom doesn't click in my head???
sqbtr
Anybody ever used finn form..
alligatorgars
Im onboard for a complete composite replacement of stringers, floor and transom. Plywood is the reason this section of the forum is popular. ( I havent seen a Cape Horn boat show up here for a rotted transom replacement yet.) I must agree with cadwelder about replacing the stringers and deck with composites also if you are doing the transom. Only makes sense. There are other products out there other than Coosa board for this.
3/4in Nyloboard http://www.nyloboard.com/products/nylosheet/styles-sizes Style G-4
