orlandoclippertim
- Joined
- Jun 2, 2011
- 106
Have orlando clipper aluminum hull. Have my transom insert about ready to go back in. The aluminum where the old wood was polyestered in was heavily pitted from water pockets in the interface. I prepped the aluminum by sandblasting all corrosion away. Cleaned with acid and alodyned it. Then 2 coats (thick) of 2 part epoxy primer.
I want to put something between the new wood and the epoxy primed aluminum to keep out any water. Something which is slightly flexible. I dont think I want something really rigid (polyester?) that when the wood is under a strain the glue just pulls the epoxy primer off the aluminum allowing water up against the bare aluminum. I am thinking a little flexibility and elastisity will prevent this. Maybe something thats NOT PRIMARILY a glue. There are quite a few through bolts in this situation ( aluminum - wood wood - aluminum ) so i am thinking of something less adhesive than the T-88 that I used to glue the 2 sheets of the wood together with.
I guess whatever sealant will have to be anerobic since no air can get between the wood and aluminum when I squish it together. I am guessing this means a 2 part (A+B) type material ?????? Is there a 2 part marine sealant ?
There is a 2 part one for aircraft windshields but it's MONSTER STRONG and maybe too visgus for this situation since my clamping force will probably be fairly limited. i also want something I can get loose if I have any problems down the road. Dont want to hve to distroy the aluminum in the hull to get the wood out ! (or maybe the next owner) I am thinking a 2 part silicone might be too hard to remove later....
What to use ? ( please no-one suggest gorilla glue ........)
Tim in Orlando
Tim in Orlando
