I have read every transom repair thread here, and most of the general fiberglass questions and I still need a bit of help. All of the wood is out, the glass is prepped, but I have some generic fiberglassing concerns. Here are my plans<br /><br />Cut a piece of 3/4 ply and a piece of 5/8" ply to the proper shape, epoxy togethere with thickened epoxy and screw with stainless screws. Let dry.<br /><br />Wet the rear transom existing fiberglass hull and one side of wood (from above)with a thin epoxy but do not let dry. Lay a piece of mat against the existing fiberglass, then using a layer of thickened epoxy, "glue" the wood against the rear of the transom.<br /><br />Wet the front side of the new transom with thin epoxy (don't dry), then install mat with thickened epoxy, then install the original inner fiberglass from the transom and let dry.<br /><br />Use tape around the seams from where I originally cut the inner transom. I left about a 3" border all the way around so I could reattach. I will feather the edges of this cut so that when I had the tape, it will result in the same thickness as the original.<br /><br />Then, seal the top with new glass cloth (using epoxy) and install another piece of mat across the front of the new transom (over the tape and seams that I did previously). I will cut this mat 8-10" (4-5 on each side) oversized so it will wrap into the sides of the boat.<br /><br />Sound OK? Here are my questions...pretty generic. The transom needs to be 1.5", which is why I am using a piece of 3/4 and a piece of 5/8. The difference I assume will be made up by the mat I install between teh new wood and the original rear of the transom. <br /><br />First of all, what weight mat should I use here and again on the front? What are the normal thicknesses for different weights of mat? IOW, what weight mat will give me that 1/8"? Remeber, there is going to be a piece of mat at the rear and on the front, so each will need to add only 1/16" to the mess. Is this enough?<br /><br />Lastly, it is an I/O (3.0 OMC) that will be in the boat. If I can, should I add braces between the transom and stringers? They weren't there originally, but I have space if it would help and make a difference as to the thickness of mat.<br /><br />Is that a detailed enough description?
