littlebookworm
- Joined
- Nov 30, 2007
- 574
To make a long story short, I broke off one of the lugs holding the power steering actuator on a 1986 Alpha I drive. I've gotten a used replacemnt inner transom plate. I've read and reread the Mercruiser manual on the procedure for replacing the plate. I've done all the disconnects on the engine (which was just installed last month). I plan to rent a hoist, lift the engine a few inches, slide it forward approximately one foot (I've got the room in the engine bay), lay in on some cribbing, and pull the inner plate. I understand that the out plate must come off as well and a new outer plate transom gasket be installed. I am working alone on this. Are this any tricks to this job? Anything I should watch out for? I used to be an auto mechanic and have been doing all the work on this boat and my previous one, so I'm fairly capable with the mechanics. I've just never done a transom plate before. Thanks in advance for any help or advice you can give. Hy
