JASinIL2006
- Joined
- Feb 10, 2012
- 5,762
Re: Transom problems with Larson 186 SEI I/O Bowrider
My hull was about 1/4" thick after grinding off the old peanut butter. I used two sheets of 3/4" plywood glued with Titebond III for the core. I followed Woodonglass's recommendations almost entirely; I covered the entire transom shield in CSM before installing it, I tabbed it in with CSM (and added a layer of CSM around the perimeter of the keyhole so the lower part, where I tabbed, wasn't built up more than the upper area around the keyhole), and then covered with two layers of 1708. It all came out to just about 2" (I believe 2" to 2 1/4" is what Mercruiser specs.)
I thought about making the transom from a sheet of 3/4" and two of half-inch plywood, and I'm glad I didn't. It would have taken me pretty close to the outer range of thickness that is specced. I figured if I miscalucluated I'd be better off with a thin transom that I could build up with layers of 1708 than a transom that was too thick...
I was really careful about the clamping and maintaining a uniform thickness of the PB. I also mixed the PB to cure slowly so I had time to fiddle around with it.
Let me know if you have any other Qs. I understand that this is a step you don't want to mess up!
Jim
Jim, glad things are coming along for you. What thickness plywood did you go with for your transom? Also, I'm assuming you wrapped your transom in CSM and put two layers on after installing. One more, how thick was your hull after all the grinding?
Jim
