JASinIL2006
- Joined
- Feb 10, 2012
- 5,729
Re: Transom problems with Larson 186 SEI I/O Bowrider
I'll be looking for it!
Jim
Jim
Great info just bought same boat my transom is good but my floor is soft right by rear seat
Question you went with 1/2 plywood for deck how much 3 sheets looking for marine plywood up here in sask difficult gonna have to pre order 3 sheets for deck sounds like enough thanks again
Sheldon
Hey Shawn, if that is the 15 ply Baltic Birch from Windsor Plywood, they assured me it was water proof glue and good for exterior use if sealed up properly.
What part of sask are you from?
If you really want marine plywood, Windsor Plywood here in Saskatoon sells it, $130/sheet, I believe it's 3/4" but cannot remember. I ended up just using outdoor rated plywood form Home Depot ($30/sheet of 3/4", $26/sheet of 5/8"). The other option is MDO (medium density overlay), it's used for making road signs, concrete forms, etc.. I think it goes for about $80/sheet, Windsor has it as well.
A lot of people on the forum suggest Aurauco plywood, but I could not find it anywhere locally.
Hope that helps.
