transom rebuild in cold garage
new2fish
hello everyone
can i rebuild my transom in a cold garage??today is 33.
my plan is cut out the inner layer fiberglass and special order a 2x18 if i can.re do the inner layer. my garage is not heated and i can not wait till may, so can i use a couple of heat lamps to cure the glass,I don't feel like to loose my engine
in the middle of lake.thanks new2fish.... and boating
oops!
Re: transom rebuild in cold garage
hi.....welcome aboard.
yup you can fix it in a cold garage......put heat lamps on the glass and if you can ....a ceramic heater.......
but its not fun...!..... i hate the cold. dress warm..in layers...youll find your self sweating in no time....so youll have to shed some layers.
2x18 s ?
your better off with 2 sheets of pressure treated ply wood....(dry the ply wood first).
if its 33 out side....you will have a month ...(mid april) to dry the wood....and rip out the old transom.....LOT'S OF TIME....the install is one day...and 48 hours cure time. after that ....the re-installation of the parts can go quite quick. the cap will take a day.
hope that helps
cheers
oops
tashasdaddy
i only disagree with opps! on one thing. i prefer 3/4 exterior plywood, once ecapsulated, it does not matter. the treatment chemical is corrosive to metal fasteners, even after the wood is dry.
oops!
td is right. pressure treated is nasty stuff.....and you would have to use special screws....for an o/b it might be the way to go.
pressure treated wood needs to be bone dry. or the resin wont stick to it. that means heat ...and you dont have it......you will have a little more tollerance with exterior in cold.
there is lots of posts on here reguarding transom replacement. you might want to hit search...and read ...read...read.
but were here for help.
(....and td....bet mine will last longer...:D :D lol)...(if it floats !)
cheers
oops
new2fish
thanks guys..
My engine is 300# 84 90hp mariner,my friend told me i can special order the 2x18( i never heard of it) The original transom was 2 inch wide.So you think 2
3\4 plywood will be strong enough???ceramic heat? I don't have it,I will use 2 heat lamps.Also going to replace the support between the transom and the livewell box. ohhh sorry about the spelling and the grammars ,english is my second language ..
Coors
(2) 3/4" and (1) 1/2" ply.
tashasdaddy
what he said ^^^^.3/4 inside, 1/2 middle grain turned opposite way, 3/4 outside. i have always used this to glue my layer together, glob it on, and spread like you were setting tile, the screw together. but you need a warmer place for it to cure, under your bed???
here's some good info: http://70silverline.250free.com/Skankybeast.html
new2fish
Thanks again guys...
My tools are limited,I will leave the outer layer then reglass it,then plywoods and after put 1/4 inch fiberglass on it for the inner layer.thanks again any info helps..
Coors
Oh, yeah, that poly is good.
You can anchor concrete with it.
Coors
But, remember, it is not a sealer; the wood needs to be incapsulated after gluing together.
and cloth, roven, biax, is involved there. Any will work.
new2fish
what???
incapsulated, I am sorry my english is limited I thought the poxy or fiberglass
will be enough for sealing.thanks.. bass fishing is the american dream...
oops!
wrapped up....sealed off....closed in.....totally covered.....
you must enclose the part and seal it so no water can reach it....(just an example)
oops!
and btw.......(by the way)......
your english is just fine...:)
new2fish
Thanks..
My buddy post to come over today,help me take the engine off..I let you guys know what happened..
new2fish
north west Indiana, I leave 30 m west from chicago.Use to leave in Florida but didn't discover bass fishing yet.Now I kicking my self in the &%*#@
new2fish
sorry, my bad.. I leave east from chicago..
drewmitch44
Yea you can use that PL stuff to glue your sections of wood together. It is verry strong strff. I used it for that and for beds for the stringers that im working on. If you use it for stringer beds to prevent stiff joint i sudjest using a thick bead of it where the stringers are going to sit. That stuff is amazing made by PL. Thash did you use it to glue wood together all by itself?
Coors
We use it in construction all the time. If you use it to glue dry wood to other wood, concrete (probably scuffed up glass); you will destroy the wood trying to take it back off, after 2 days of cure.
