Transom Repair
davebuc
Looking for input:
1988 23' Glastron 96" beam. Big boat 3450lb dry. 5.7 Merc w/ Alpha one.
Had leak at transom. With engine, outrive, gimbal housing, inner & outer transom brackets removed, found rot on edges of drive cut-out.
Picked at it with a chisel today.
It goes for 2 horizontal feet on either side of the cutout.
I am wondering if people replace part of the transom wood panel, or if replacing the whole thing is the only reasonable solution. (like a 3' x 2' full thickness portion, and fiberglass it in?
The transom panel in my boat is massive: 88" wide, 38" tall. 2 layers of 3/4" plywood.
the rot stops at the top of the outdrive cutout, which is about 19" below the top of the transom.
Also, any tips for removing the old transom faster?
Thanks,
Dave
Friscoboater
Re: Transom Repair
First of all welcome to iboats. You might want to take a look at my Glastron thread for great information on transom replacement. I replaced a complete transom in my boat last winter, and the link is at the bottom of the thread. I've seen people replace partial transoms before, and they have had great results. It is really almost easier to replace the entire thing. You might want to check out classicglastron.com for great info on old Glastron boats.
As far as replacing the transom faster, there really is no easy way. You just have to chip away little by little, and it will come out. If you have any questions feel free to send me a private message.
BWT
Re: Transom Repair
Well, there a couple ways of looking at this. Given that the rot is in the middle of the transom I think I would look at approaching this as a partial replacement. Going this route eliminates alot of fiberglass and gelcoat work. That being said, the area that you will have to cut open will be larger than the rotted area alone. If the damaged area is 3x2, I would expect to cut open an area 4x3. With all of the mechanical out of the way I would do this from the exterior side of the transom.
Cut off the outer skin of glass with a thin kerf blade. Fein makes a great tool for this (multimaster) but is a little pricey for a one time use ($300?). A skill saw with the depth set to the thickness of the exterior skin of fiberglass would also work but will make alot more dust (make sure you're wearing a good respirator, tyvek suit and eye protection!)
An important part to keep in mind with the planning is that you need to stagger the joints between the inner and outer layers of plywood making sure that one overlaps the other.. You don't want to have the joints from these two pieces lining up otherwise it will be a weak spot. For example: If the actual rot area is 24"x24", I would cut the outside skin 36"x36" (only the skin, not the plywood), then the outer layer of plywood roughly 3" smaller all the way around, and the inner layer of plywood 3" smaller than that all the way around leaving you a square that is to the actual size of the rot; 24"x24"..
Best ply to use is a marine grade (okoume or merriante) and laminate in place with epoxy. Use screws to temporarily suck everything together so that there is a good bond between the two pieces of ply as well as the inner and outer layer of fiberglass (#10 screws 1 1/4" with fender washers every 12" or so) Actually screw the inner layer of ply to the inner layer of glass. Let the epoxy set, remove screws and repeat the process screwing the outer layer of ply to the inner layer of ply. Continue the stacking process until everything is in place. I wouldn't try to do both layers at the same time. The goal is that during the re-building process, each layer is larger than the previous so that all joints are overlapped. If there are any gaps along any of the cutout seams, pack them with thickened epoxy so there are no voids..
After everything has cured, remove the temp screws and epoxy the outer layer of glass back in place (again, using screws to pull everything together) making sure to get it in the original location. grind the edges of the fiberglass skin back to a taper roughly 4" wide; 2" on each side of the seam) and layup glass matting (1.5oz) over the entire seam (probably 4-5 layers). Sand down with 80 grit so the glass layup is flush (or even a little low) with the rest of the transom. From there, get some gelcoat colormatched (www.spectrumcolor.com), lay it up and wetsand it smooth and flush. Make the cutout through the new plywood and re-mount the mechanical with a marine grade bedding compound (NOT SILICONE!! I recommend 3M 4200). This is a pretty concise explanation. I've done this many times and it isn't all that difficult, but it does require a bit of fore-thought and planning. Hope this helps, pm me if you have any further Q's.
Good luck!
