Transom Replace/Repair '85 Skeeter SF180
Saperry
Anyone here have advise on best way to fix?<br />I saw some stuff called seacast pourable composite transom. Anybody know if it works. Both the inner and outer fiber glass skin seem to be in good shape but the transom sure does flex alot. I don't want to remove the deck from the hull to replace. If that is the only way to do it I will. The Boat is an '85 Skeeter SF180 Fish Ski. Can all the old wood be removed from the transom with out removing the deck from thr hull.
Yepblaze
Re: Transom Replace/Repair '85 Skeeter SF180
If you can get a chainsaw in there all the way through the rot, and vacuum it out real good it might be ok.
