transom replacement on aluminum boat
bipshoft
Re: transom replacement on aluminum boat
Bob
glad you mentioned sealing the lower unit as I will be needing to do that when I get to the impeller change :)
Also, I was looking at painting the boat with interlux, so is it safe to assume I should use that on the hull prior to mounting the transom?
thanks again and hope to have more pics this weekend, been really hot the last few days here so not much accomplished
also got some of the decking in the aft section removed and found lots of foam, good news it is pretty dry, but will be getting ripped out so I can seal the seams and rivets with gluvit
thanks again for all the great advice I am getting
Bob_VT
off topic..... lower units do not get any sealant! It was just an example of the horror's seen here ;)
bipshoft
Bob
then it appears I have found the correct place to learn about the correct way to do things
thanks for all your valuable information
