Hello
My trailer is a bunk style trailer. I bought the standard transom saver for that style of trailer. It appears that the transom saver is still too short. How far up should I tilt the motor. I am concerned that the skeg will drag the ground if I use it at even the longest position. Typically how far up should I tilt the motor? It looks like I need to put some sort of spacer on the crossbar or else put a crossbar towards the rear end of the bunks and attach the transom saver there. That would have the added advantage of not having me crawl so far under the boat to put the pin in the transom saver. Any comments?
TerryMSU
TerryMSU
