Transom Saver?
dnellie
I just purchased a 07 Zodiac Classic MK II with a 30hp Tohastu 4 stoke. Pretty heavy motor(for that boat) I believe. I have a pacific trailer that I am currently fitting and adjusting for the boat. Most of the time the trip to launch is under 5 mins. However I will be taking a couple of longer trips as well. I noticed a bit of torque (to say the least) generated with bumps on the road. If anybody with knowledge and experience in this area could chime in that would be great. I searched previous threads and found one pretaining to my issue. But just checking to if anybody else has a similer set-up and what they did. Thanks
PS. No oil in the cylinders!
Drowned Rat
Re: Transom Saver?
Well, I'm not familiar with that trailer, but if you have to tilt your motor up when trailering, I would absolutely use a transom saver. If you can leave the motor vertical, that's best, but clearance is an issue obviously. I trailer my inflatable with an 18hp 4 stroke secured with a transom saver all the time. Never had a problem.
deejaycee_2000
Re: Transom Saver?
Here is a nice idea for you .... it is attached to my trailer permanently and swivels down so it is out of the way when you wanto launch the boat .....
dnellie
Re: Transom Saver?
I could transport boat with motor in the down position. However, the torque is still there non the less. By no means is my commute to a launch like baja. But it is bumpy
nobrainsd
Re: Transom Saver?
A transom saver is a small investment to protect the integrity of your transoms glued seams. Also, be sure that the transom is physically supported by the trailer bunks. This can be inconvenient, but I adjusted my bunks, the position of the forward winch post and the trailer axle position to get a properly balanced trailer that supports the transom correctly.
