Re: Transom Savers Are A Waste Of Money - Yes or No?
Ding, It is not true that there is minimal torque applied by thrust when in the running position. The motor is attached to the upper portion of the transom. The thrust is being applied at the propeller level of what is essentially a lever. Not only do you have this thrust working to pull the top of the transom out, but it is trying to push the transom in at the lowest point of the bracket that holds the motor onto the transom. Combine this with the fact that, when at rest, the weight of the entire motor is outside the transom, there is that leverage as well. When the motor is in the tilted position, it is relatively balanced. Even though the leg is longer, the powerhead weighs more, so it is mostly balanced. <br /><br />The only reason I am arguing this subject (besides the fact that I am sort of bored and can't wait to get crackin' on my next project) is that a motor in the trailering position does not generate enough movement to have enough inertia to apply significant force to the transom. If the leg jumps up, the powerhead goes down. When the leg is comeing back down, gravity is fighting the powerhead going back up, which reduces the energy of momentum the leg may have developed. <br /><br />When the boat is in the water, at a standstill, and you apply throttle to get it on plane, there is little dampening the energy that is applied to twist the transom due to thrust from the motor. Yes, the boat moves, but all that weight is still being forced into motion by the thrust from the motor, which is applying that force to the transom in a twisting action. Yeah, using the term "mash" was a poor choice of words, but we all know that the proper way to drive a boat is to apply enough throttle to get the boat up on plane in the shortest time and distance, to save fuel and reduce the lenght of time the boat is being stressed. For a lot of boats, that means WOT or near WOT, and basically that translates to "mash". If you are slowly bringing a boat on plane, you are wasting gas and hurting the engine by not getting it into its powerband.<br /><br />Its too bad we just can't get "Mythbusters" to do a segment on this. If anyone could prove it through instrumentation, they could. I don't really want to argue about it any more, I still insist that it isn't hurting anything to use a saver, I just hate the way it is marketed, because it is not truth in advertising.<br /><br />I think the best we can do is to agree that everyone has voiced good points, and that none of this thread is going to change anyones decision as to whether they use a saver or not.
