transom seal
quigz
i have a 1984 sea ray and i need to replace the transom seal is this a difficult task or can it be done in a driveway?
Howard Sterndrive
Re: transom seal
easy - can be done in the driveway. With a lot of hot, soapy water, the new one can be stretched over the leg if you just remove the trim tab, water director covers, and propeller.
Do not buy aftermarket - spend the extra $30 or so for the OEM one and it will last 20 years.
quigz
Re: transom seal
thanks, i have also heard that it could be easy just to take to leg off do you know if that is true?
southkogs
Re: transom seal
Removing the drive on the Stringer is pretty easy. You've got some added mechanical shift "stuff" that I'm unfamiliar with (mine's electric shift) but the drive should come off very easy.
Howard Sterndrive
Re: transom seal
As long as you don't damage the $750 shift cable (when available), yes, removing the drive is quite easy. Take the battery out of the boat before doing anything with the shift cable.
jerryjerry05
Re: transom seal
Like Howard said, buy the OEM one.
I was hired to install one. The guy cheaped out and it split while installing. He had to buy another,the second one was OEM and it went on right.
There is a top and bottom.
