transom thickness& shimming for transom plate
xylene
Hi,fellow boaters I have a stumper I am dealing with.Im rebuilding my transom in my 1971 Sea Camper.The best I can remember is the thickness of the fiberglass1/4 in.+ 3/4 plywood with another 3/4 smaller area behind the transom plate for support.The area was rotten considerably.What I need to know is the thickness behind the transom plate to the 1/4 in. fiberglass.This particular setup is with a merc o/d 1971 pre-alpha with 888 302Ford.Also info about the shimming would be very helpful.I did read about a prior post but do not know if it applies to my setup?It said something about 2in. -2 1/8in?Thanks for setting me straight.
xylene
Re: transom thickness& shimming for transom plate
wow,wow,wow What a fast response.Thanks Don S.I didnt know the web site existed.May they be fair wind in your sails!
Ayuh,...
I stated 2" to 2,1/8"....
But,...
Don corrected me,... Again,..... It's 2" to 2, 1/4".......
Don S
Ayuh,...
But,...
Correct you :confused: :confused: Ell, man, you didn't even post the 2,1/8" dimension, how could I correct you:eek: :rolleyes:
