transom ...
duckee
ok so my transom is partially rotten ... my thought is to cut out the bad section and repair it ... but with safetyy in mind (and not wanting to lose my motor to the lake gods) i thought id ask the community what they think ...
mtduckhunter
Re: transom ...
you should repair the whole transom. because whats not rotted is most likely wet and will soon be rotted also.
so put some time into it and do it right the first time, . . . you dont want to have to do it again. :)
duckee
Re: transom ...
ok cool ... thats what i figured ... so my plan it to pull the top half of the boat off to make repairs easier ... how many guys and how many boxes of wheaties am i gonna need ? i may build a frame and use a couple chain hoists to lift it ... or possibly if my dad wouldnt mind ... i may hang it from the rafters of the barn for the winter while i do the work ... has anyone tried any of these before ? could you guess the weight of the top half ? its a 17' glastron trihull ...
NJ lakes
Re: transom ...
Duckee:
I just put our boat into the water after doing a similar job this spring. It is a 73 Glasspar Citation. There was no wood left, just what looked like leaf mulch. What I did was use a Rotozip tool with a diamond abrasive bit and cut the top off of the transom, then dug out the residue and vacuumed it up. I cut a cardboard template of the transom, and cut plywood to fit. Since the opening was smaller than the width of the transom, I had to cut the pieces (I used two sheets to give the proper thickness) at a diagonal to allow it to slide in. I used plenty of epoxy resin. The outer skin had actually taken a set with a curvature due to nothing being inside the shell, so when I got everything together I used stainless steel deck screws to attach a sheet of plywood to the outside to straighten it, which was later removed. The shell had some fracturing so I layered fiberglass cloth on the outside, and used a 1/8" sheet of aluminum when I mounted the motor. With all the epoxy resin, I wouldn't be surprised if it was stronger than when it was new.
Check the Fiberglassics website, and also "The Rot Doctor" for other examples of how to do a job like this. It is a messy job, for sure.
tcindie
Re: transom ...
I can't imagine it would be much.. maybe 100lbs? If it's all glass it's gotta be fairly light weight.
The only thing of weight on my 14' larson at the moment is the engine -- gotta pull that one of these days. but otherwise I'm sure I could manage to move the whole thing, top cap and all, by myself... I think it's more an issue of size than weight. two people should be able to handle your cap pretty easily, three if it's being uncooperative and twisting around alot.
duckee
Re: transom ...
well i think either way it is lifted i may brace up the inside to keep it from twisting too much ... this is my first project and im excited ... i just dont want to get in a hurry and make it dangerous in the end ...
oops!
Re: transom ...
hi duckie....
there is about a thousand threads on transome replacement here......
read the compleated projects forum.....the hull ext thread has a transom replacement with pics......
with all that detailed info....you will have no problem....
you can cut the back top off....or the best way is to lift the cap......you might be able to just slide it foward........
get a 4 inch angle grinder.....
read the safety basics thread at the top of this forum.....then start by posting picks....we will walk you thru it no problem
cheers
oops
duckee
Re: transom ...
thank you all soooo much ... i thought this was gonna be an expensive nightmare ... but now i am at ease and i may still use my floor idea ... tee hee ... little pricy but it will look sooo much bettar in the end ... and it will be less work too ! thanks again everybody !
mtduckhunter
Re: transom ...
i just got done with mt transom rebuild and i done it all by myself, to remove the cap, . . i just took some 2"x6"s and leaned them against the hull and slid the cap down. :)
