Transome Drain Fitting Replacement
sybaris2
Last Fall I was winterizing my boat (2005 Crownline 220EX) and while I was taking out the brass drain plug the whole fitting came off. It was only held on by 3 small brass screws and required some torque to get the plug on and off so it kind of seemed inevitable that it would fail some day anyway. I was surprised to find that there was no epoxy or other adhesive used behind the fitting.
So I'm looking for suggestions on repair. My first thought is to go up a size with the screws and use the same screw holes. I could also invert the fitting and drill new holes. I have also thought about a different fitting altogether as the torque to remove and replace the brass plug over 14 years probably aided in its failure.
Any suggestions much appreciated.
your transom plug flange threads are tapered for the brass pipe plug. you cant flip it around
you should not need a lot of torque to seal. your turning it too tight. it would seal if it was only finger tight, then turn 1-2 flats past that. that is it.
take some 5200 and bed it in, using new screws
sybaris2
I said invert it, not flip it. The casting makes it pretty obvious which side faces out. Thanks for the suggestion.
harringtondav
The yellow flag that popped into my mind is "why did the screws pull out?" Now would be a good opportunity to make sure the transom isn't mush around that bung hole. Scrape the hole with a dental pick to make sure it's solid. Coat the hole with sealant per SD. This will protect the raw plywood.
JASinIL2006
That's the first thing I thought, too, especially if the flange wasn't bedded in some sort of sealant.
