Last Fall I was winterizing my boat (2005 Crownline 220EX) and while I was taking out the brass drain plug the whole fitting came off. It was only held on by 3 small brass screws and required some torque to get the plug on and off so it kind of seemed inevitable that it would fail some day anyway. I was surprised to find that there was no epoxy or other adhesive used behind the fitting.
So I'm looking for suggestions on repair. My first thought is to go up a size with the screws and use the same screw holes. I could also invert the fitting and drill new holes. I have also thought about a different fitting altogether as the torque to remove and replace the brass plug over 14 years probably aided in its failure.
Any suggestions much appreciated.
