Transome Re-inforcement
lwcrew
I need to "beef up" my existing transom to support a larger OB engine. The boat is a 1990 1700 series16' Bayliner Capri. It currently has a 65hp and I'm looking to upgrade to a newer 80hp. All advise and comments welcome. I hope everyone had a great new years!
alden135
Re: Transome Re-inforcement
That boat's already rated for 85hp. The only reason you'd have to beef it up is if it's rotted. In that case you'll need to rebuild the transom.
lwcrew
The Coast Guard Decal on the boat says it's only rated for 50hp??
It is really a matter of extra weight in the stearn and extra torque right??
lwcrew
The Coast Guard decal says it's rated for 50hp???
Solittle
Lawayers love guys who put 80 ponies on the transom of a boat rated for 50 - - oh and forget your insurance company. They will deny ever having you for a policy holder.
Bob_VT
You have already exceeded the 50 hp rating on a 17 year old hull. Be very cautious and inspect the transom and stringer's for rot (I once heard a rumor that in 1990 Bayliner's it was common).
IMO if you have a good running 80hp do the job right from the start. Just "beefing up" only works if done the right way.
lwcrew
Well gentlemen, I heeded your advise and had the transom check for rot, and was pleasently suprised to find none. Also I purchased a 50hp 2-stroke with hydroplanes and am having it installed in the place of the 65hp. Thanks for the advise/help.
Fire9mars
I did a similar projet 2 years ago. I had dual engine/outdrive in my '74 fiberform and replaced them with a 225 E-tec (outboard). After in-filling the transom and mounting an off-shore bracket, I mounted ppt 2x4's on inside of transom and used the bolts of the off shore bracket to hold them in place, and then bolted a "triangle" support perpendicular to transom and directly into stringers. When I power up there is no flex or delay. The forces are transferred directly into stringers. The e-tec is positioned 29" back of transom and at 524 lbs it does create a moment arm...I have used this for over 50 hours in PWS and it is very solid.
