travel trailer frame convert to boat trailer
jim372
i have been thinking of use a travel trailer frame for use as a boat trailer
beef up the frame , put on bunks for boat to set in.
may only be one time use
zopperman
Re: travel trailer frame convert to boat trailer
What kind of boat? What's the weight rating on the axle?
jim372
i have been looking on ebay and could pick up a project boat with out trailer
for good price .
in they 20 ' - 25 foot range
i was looking before at weight of 26' tt and if i remember right around 4,000 lbs
2 axle w/ brakes
zopperman
I would probably just spend the money on a boat trailer... but I don't see why it couldn't work as long as the axle could tak ethe weight. I made a utility trailer out of an old pop up camper and it can hold a significant amt of weight and ive never had any problems aside from a nail in the tire. Happy welding :D
Bamaman1
Jim: I've got a 31' travel trailer, and have a little experience rebuilding travel trailers.
You'll find he travel trailer to probably have a couple of 3500 pound axles with twin electric brakes. Depending on the quality of the travel trailer, the weight of the trailer including all the guts may be more like 5000 lbs. Stripping the travel trailer from frame will be a bunch of work, and you'll probably be surprised how weak the travel trailer frame is stripped.
Using the frame the travel trailer would probably work, but you may need to add some supports, or possibly take out some supports. Who knows if the trailer will be properly balanced for a pontoon boat when stripped. If you had a wreck with such a trailer, you may be open to some liability issues due to the original intended use of the trailer.
You can buy a new 24' pontoon trailer for $2000 from many sources. Used trailers can be found for half that amount. I personally would suck it up and buy a trailer made for pontoon boats.
