Treated Wood vs Aluminum
Rub-a-dub
I have been reading about treated wood vs aluminum causing electrolysis.
Does this apply only in areas where water is in contact acting as an electrolyte,
or in dry areas too? I built a shelf with treated plywood in a dry storage
compartment which contacts my aluminum hull. I use my boat in fresh water
only.
jigngrub
Re: Treated Wood vs Aluminum
Did you paint or seal the wood with anything?... or just put it in there raw?
kfa4303
Banned
Yeah, raw treated wood on aluminum isn't great, but if you slap a few coats of paint, sealant or fiberglass on it that will help.
fishrdan
If it's CCA treated plywood you'll be fine, though I doubt you have CCA treated plywood as it's expensive and difficult to find. It's probably cheap and easy to find AQC treated plywood, the stuff that will eat your boat.
Sealing treated plywood with paint/clear finish will help isolate it, but I still wouldn't want treated plywood on my aluminum boat. When the chemicals eventually start leaching out (failed finish)......
pckeen
I would replace the shelf with untreated plywood.
Georgesalmon
Most treated wood has some copper in it and that's what makes a battery with your aluminum. If the wood is isolated from the aluminum its OK but whatever seal you use to do that may break down in time.
Rub-a-dub
Had I known about this before hand, I would never had used treated wood. I think the best thing is to remove it and replace with untreated wood. Thanks for the posts ........ :)
jbcurt00
You will want to seal any wood you put back.
