I agree with you to a point RF, but I don't know what you mean by this? A V hull, or Deep V, giving you a hard ride? I do know most boats were either flat bottom, or "Semi-vee", back in the 60's, & early 70's. Meaning they were a V in the front but were flat bottomed at the transom, with either round, or angled (non-trip) chines, these boats were somewhat harsh riding in the chop. This was before the introduction of the true V, or Deep V design, (ending at the transom) like most boats are made nowadays, with maybe an exception of aluminum boats.
Glastron was one of the 1st boats to have a full V bottom, meaning V from stem to stern, most builders thought it too risky to build a boat so small with a V bottom, because of stability issues, usually they only ventured into making 18' and larger V bottom hulls (eventually all the other builders gave in, due to competion, and found ways around this) A true V bottom boat, or a Deep V bottom boat was, is, not very stable, especially in smaller sizes. If you saw one of these Glastrons back then, you couldn't help but notice a scary list to the side at rest when somone boarded, or got out at the dock. The tri-hulls filled the bill in between at that time because of better stability, on smaller size boats. This was also about the time the Cigarette Deep V ocean racer offshore boats were designed, & produced, because stability was not as much of an issue with these longer hulls, and they rode better in the ocean, they sacrificed some speed (about 15%), for a smoother ride, and gained some back because you could travel faster through the chop, and hold more speed, then a pounding, or flying, Semi-V raceboat. I haven't followed aluminum boats design to know if they make a V, or Deep V in aluminum, but I'd bet the smaller ones 16' and under are still Semi V's due to stability issues, again fiberglas tri-hulls are your best design for this size, & smaller.
Finally a boat with a V bottom at the transom, is a true V, or Deep V depending on the dead rise, anything else is a Semi V, or flat bottom.
I lived through these yrs, and payed some attention along the way. So much for my lesson of the day, I know, I know, I'm a windy old fart
