I'm new to fiberglassing, and I think I have a bit of a tricky repair situation. The fiberglass skin delaminated in a couple of places from the backside of the plywood-core transom in my Achilles SU-16 inflatable. The tricky part is that the delamination extends down below where the floor rubber wraps up and around from underneath. So what I've got now is an 8" half moon area above the rubber line where I've ground the glass down to the wood and out to where it's solidly bonded to the wood, and a roughly equal half moon area below the rubber line where the rubber is firmly attached to the skin, but the skin is pulled away from the wood. The wood is good, no rot. I really don't want to detach the rubber to fully remove the delaminated skin - it's tightly glued now and I'm leery of being able to rebond the rubber to new fiberglass, and of trying to work behind a stretch of partly detached rubber. If I glue the skin back to the wood with epoxy resin, I'll be left with a butt-joint with the epoxy and glass repair of the area above the rubber/skin edge (the skin is maybe 3/32 thick). In retrospect maybe I should have cut the skin well above the rubber line so I could taper it and glass up onto it... I guess my question is, what is the best way to deal with the joint that's going to exist where the old skin is glued back to the wood, and the newly exposed area above is re-glassed? I could extend the new glass for the area above the rubber line to an inch or so down behind the skin before glueing it down, so there would be some area of glass for the skin to bond with, and avoid a total butt-joint at the skin-edge. I'm assuming if I leave a butt joint between the old skin edge and the new glass above, that it will just flex and crack. I guess I could also trim the rubber edge back an inch or so and lay a piece of cloth over the top of the joint as well. My other thought was to put a fillet of thickened resin at the butt edge of the glued-down skin, and feather it out onto the (wetted) fresh wood above, with some plain resin over it. That would give me an area to glass up on to. I just don't know which approach gives a better bond - old skin directly to wood with nothing but slightly thickened resin, or old skin with a band of glass behind it along it's edge.
As I said, I'm new to glassing so I'm hoping for some experienced advice about what to expect and how to proceed.
Mike
Mike
