trigger and distributor?
dilli1
I had a crispy wire from distibutor to trigger. should I replace both or is there a possible other cause? I do not want to fry a new trigger
thnaks
timmathis
Re: trigger and distributor?
What year and size model? To most people a trigger and distributor are the same thing? Be more detail so we can understand and give some advice.
Do you mean stator instead of trigger by any chance?
Clams Canino
I think he meant distributor to switchbox. Also... the wires are most likely a case of rotted rubber - not crisply from heat.
-W
dilli1
I am calling it a trigger because it looks like the pictures of triggers when I look through the parts list on this site. It is black solid state part under the flywheel I assumed the distributor was where the plug wires came out of.
not positive of year think 84 50 hp 4 cyl.
thanks
jmburock
sounds to me like one of the trigger wires is destroyed, would look under the flywheel at where the wires come out of the trigger, you probably need a new one. if they are toast at the switchbox, they probably are all the way back to the trigger ...
Clams Canino
If the motor has a real distributor ignition... the trigger is IN the distributor. The 3 wires going to the port side of the switchbox are the trigger wires. That thing under the flywheel is just the stator - for charging the battery only on the older distributor ignition mercs.
Now if there are more than two wires coming out of that thing (anything)under the flywheel - all of the above is moot.
Agreed a serial number will help here.
-W
dilli1
I will try to get serial number tonite. It definetly is not the stator(which is directly under flywheel) trigger is under flywheel hub(previous post - removal problems) from what I gather I should be safe just replacing the trigger. next problem is htis site has just about every trigger listed except the one I need OEM # 96451 any help there
thanks again
ricksrster
Iboats has the CDI brand and so does boat fix.com
