tonyg11780
Thread starter- Joined
- Mar 29, 2008
- 75
Good afternoon gentlemen,
I have a 2003 Mercury 60hp bigfoot 2-cycle. It has a dead miss on the number two cylinder. I tested it with my spark tester and it is not firing at all. My first thought was the ignition coil. To check this I unplugged the wiring from the number 1 cylinders coil and plugged it into the number 2 coil. The plug started firing then. I then did the same thing in the wiring going to the trigger. I swapped around the number 2 and number 3 cylinder wiring coming from the trigger and number 2 started firing again. But hooked up correctly it will not fire. Now does this tell me that the trigger is bad? I have never had to replace a trigger on anything before, so Im a bit skeptical. Any advice would be greatly appreciated.
Tony
Tony
