Trilobe Pin
timriveroaks
I have a 1990 Fisher Marine with a 1989 Mercury 60 HP 2 stroke. I am about to remove the tilt trim motor. Everything I am looking at shows there should be a trilobe pin in the top ram pivot. There is not one nor a place for one on mine. I also do not see a clip on either end of the rod. Am I missing something or do I just drive it out?
There look to be at least two different PTT systems you can have on that motor. The three ram PTT system should have the trilobe pin. The single ram PTT system doesn't. What do you have?
timriveroaks
Single ram. Thanks for your reply.
