bluechevyy
Thread starter- Joined
- Oct 23, 2009
- 52
I've ask through a couple other post but, haven't really figured this out. I have 2005 Mercury 9.9 4-stroke with electronic ignition.
1st- intermittenly the ignition and the trim quit responding completely. If I waited about 20min. it would work again like nothing was wrong.
Now-Neither work at all (waiting or not). The engine won't trim and/or start with no sounds at all. I probed the power to the two main red wires under the engine cowl and there is 12v. I checked the 30amp fuse in the bright yellow holder under the engine cowl also and it looks fine. I swapped it with the spare in the holder and still no response. I probed one side of the socket in the fuse holder and it has 12v.
What do I check next?
The only thing on these posts that I have seen that might be something I need to check is the starter solenoid. Does the solenoid provide power to both the starter and the trim?
Please help with any suggestion/ideas.
Thanks,
Curt
Thanks,
Curt
