Well, I made a rookie mistake a couple of weeks ago and forgot to raise tilt the drive when I pulled out of the water. This of course resulted in the skeg of the outdrive draging up the ramp about 15-20 feet before I noticed...
I guess it was only a matter of time... The other day when I was on the lake, I heard a thump-thump sound and I noticed that the trim wasn't working. When I pulled the boat out of the water, both trim cylinders where hanging and and where disconnected from the mounts on the drive shaft housing, because the mounts had failed. There are huge chucks of aluminum missing and all of the mounting h/w guts where gone.
Luckily I was able to rig a steel cable to hold the drive off the ground, so I could trailer the boat home. That was lots of fun...
My question is, can the trim cylinder mounts be fixed by a weld shop of some sorts? Or, do I have to replace the upper drive housing?
Let me know if you need to see pics of the actual damage.
Thanks for your help!
